Wrong morter mix on pre pitch
Discussion in 'Shower & Bathtub Forum & Blog' started by onedotlow, Feb 29, 2012.
  1. onedotlow
    onedotlow onedotlow
    Feb 29, 2012
    Pilot
    Rowlett, TX
    This is my first try at a shower rebuild. I removed a fiberglass 1 piece to replace with rain shower.
    I was so proud of the preparation, blocking, slope to the drain etc. But, I misinterpreted the mix for the pre slope. I used a 4:1 mix of morter & sand. I know now that it should have been potland cement and sand. It has been 2 days & it either is drying very very slow, or it is never going to dry. I can sweep sand off the top forever. After two days, I can walk on it, but it will still gouge out with any object. I think I know how this is going to go with you guys, so lets just get it over with.......
    Thanks in advance,
    Joe
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Sorry to hear about your shower floor.
    The proper mix for a dry pack is 4-5 parts clean washed sand and 1 part Portland Cement.
    Mapei sells a ready mix which is just called 4-1. It is much stronger if you add the ad-mix for it.
    Dry Pack can be walked on easily the next day and often sand can be swept off to a point. Sound like to me that you used either a ready made mortar mix (or thinset) and sand so your ratio of sand to cement is more like 16-1 which is not going to cut it I'm afraid.
    Mixing dry pack is an art and you need to ensure you do it right. It is often advertised as an easy process but it is not if your not familiar with good mixing techniques or if you have limited tools at your disposal. A garden hoe and a clean wheelbarrow can pull it off. Best to make a small sample batch and hone your mixing skills before you go all in on your shower build. Dry Pack's should be 1 1/2" at the thin set point and reinforced with stucco mesh or the like. The should not bite into a wooden sub floor so a slip joint should be used. The heights and approaches vary depending on wood or concrete assemblies so check the TCNA, TTMAC or ANSI specifications for the right set up for your home.
    We like to dry mix the sand and the cement very well. Take half the product and mix it on the wet side. Then we slowly add in the dry product until we have a good dry pack mix to work with.
    Last year I started using mapei's Mapecem Fast Setting Screed Mortar and this is an amazing product. Just add water and mix. It is wetter than drypack and more user friendly. It can be covered with a sheet membrane the next day 14-16 hours.
    Love the stuff.
    JW
  4. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    I'd re-do it. Sounds like your a guy that likes to do things right also.
  5. onedotlow
    onedotlow onedotlow
    Feb 29, 2012
    Pilot
    Rowlett, TX
    I ripped it all out. It didnt take long. If anyone needs my wife`s recipe for sugar cookies, I think I have found it.........
    Joe
Similar Threads: Wrong morter
Shower & Bathtub Forum & Blog Handles turning the wrong direction? Nov 14, 2015
Shower & Bathtub Forum & Blog Wrong grout for flat pebble shower floor? Jun 3, 2014
Shower & Bathtub Forum & Blog Shower Panel Install Gone Wrong Nov 1, 2013
Shower & Bathtub Forum & Blog Wood Framing and Tile Failures - "What went wrong and why" - Investigating Reports Jul 7, 2013
Shower & Bathtub Forum & Blog Overflow gasket wrong taper for old tub Jan 1, 2013
