would like to install a toto with a floor supply line
Discussion in 'Toilet Forum discussions' started by noeffort, Feb 28, 2008.
  1. noeffort
    noeffort New Member
    Feb 9, 2008
    70.134.226.124
    Hi,
    I'm finally going to replace an American Standard Lexington One piece that has caused a lot of problems over the years.
    Came across this Terrys Toilet ratings and would like to go with a toto..
    The problem is the supply is from the floor, 5-1/2" from the wall and 6" from rear center of old toilet.
    I can get to the the pipes from below if I have to move the supply. Would like to know if the Ultramax would fit.
    I have the toilet specifications and the footprint isn't descriptive enough.
  2. Terry
    Aug 17, 2004
  4. noeffort
    noeffort New Member
    Feb 9, 2008
    70.134.226.124
    Hi Terry,
    Thats great news! Almost took a sledge hammer to that lexington many times!!!
    Can you clarify on the 3" to the left.... where is the point you are measuring from?
    I told one of the plumbers at work about your toto recommedations and he swears by them too!
    I forgot to mention, I wanted to go with the elongated bowls, not sure if the footprint is any larger.
  5. Terry
    Aug 17, 2004
    If it comes from the wall, then 3" works.
    Reading your title on the post, I realize that you want to come through the floor,
    You will need at least 5" or more for that.
    Reading your post, you have 5-1/2"
    It should work.
  6. noeffort
    noeffort New Member
    Feb 9, 2008
    70.134.226.124
    Yes, the supply is coming up thru the floor at a distance of 5-1/2" from the wall.
    From very back center of the old toilet to the left where the supply is coming up thru the floor the distance is 6".
Similar Threads: install toto
Toilet Forum discussions [Toto Carrolton] Any seats that can be installed with external access only? Feb 4, 2017
Toilet Forum discussions Installing a toto ultramax II Jan 31, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Parts needed for TOTO CST244EF#01 Entrada installation? Dec 13, 2016
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
