Pete C
My Vaughn indirect is leaking like a sieve. Yet another victim of my very hard acidic well water.
I am in the process of installing a softener/pH balancing system which will hopefully solve this problem. A while back, when heating oil was 4 bucks a gallon, I said screw it and found an almost new electric, resistance water heater on CL. My plan was to go ahead and install it. At 4 bucks a gallon, i figured it was a no brainer.
Now, they're damn near giving oil away which has me wondering if I should reconsider. I know <2 dollar oil won't last forever, but will it last long enough to consider another IDWH? I am a big fan of buying stuff used and was thinking if I could find one on the cheap, it might be worthwhile to give it a shot and when oil goes to 5 bucks a gallon, install the electric or maybe even go with a hybrid. I have also considered getting a tankless coil and going with a tankless coil/electric water heater series setup. I would use the TC during heating season and just the EWH the rest of the year. This could be done for the price of the coil, a few ft of pipe and about 30 ft of 8-2 romex or whatever it is I need for the EWH.
I would like to eventually go to a hybrid and a multisplit. Maybe keep the boiler around as an assist when the temps get down below 20 degrees. But, for now, with cheap oil and a functioning boiler, I think I will hold off. Besides, just dropped a decent chunk of money on a new kitchen and my checking acct needs to take a breather.
