Workaround for slight damaged closet flange
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rdtompki, Jul 30, 2007.
  1. rdtompki
    rdtompki New Member
    Dec 21, 2005
    Iowa
    I'm remodeling a small bathroom on a slab and the flange appears slightly damaged - the slot in the flange looks slightly enlarged and I'm concerned that the normal bolts might pull through. I definitely don't want to replace the flange. I could use a piece of stainless threaded rod and a stainless washer and self-locking nut in place of the bolt. The washer would be larger than the normal bolt head.
    Does this sound as though it might work?
    Rick
Similar Threads: Workaround slight
Plumbing Forum, Professional & DIY Advice Workarounds to use single handle bathroom faucet with 8" pre-drilled holes? Sep 13, 2010
Plumbing Forum, Professional & DIY Advice S-Trap Workaround Feb 14, 2009
Plumbing Forum, Professional & DIY Advice Cast at a slight angle coming into the house Dec 1, 2016
Plumbing Forum, Professional & DIY Advice Strainer drain vs. slightly cocked porcelain sink Aug 25, 2016
Plumbing Forum, Professional & DIY Advice Solder joint had slight bind - is this a problem? Mar 27, 2015
