Woodford Model 17 Faucet Leaking
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by adl9413, Apr 24, 2006.
  1. adl9413
    adl9413 New Member
    Apr 24, 2006
    I have a Woodford Model 17 faucet and is leaking when I hook a hose to it. It inside the wall therefore, I am not sure why's or where it's leaking. Can you tell me what or why it'd I am seeing this leak?
    Thanks,
    Albert
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Hose bibb is defective. Somewhere at some point a hose was left on it during the winter/freezing months possibly and water could not escape the faucet, thus the reason it froze and broke.
    When you take that faucet out, 2-3" behind that brass spigot you will find a belly in the copper where it bulged out and broke.
    Replacement is the only way to go; the only prevention is having nothing attached to that faucet so it can drain. Otherwise it loses its protective features altogether.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Woodford makes this now
    https://www.buywcm.com/egl/products/group.asp?pgn=19
  5. adl9413
    adl9413 New Member
    Apr 24, 2006
    First of all thanks for your quick replied. I am a rookie at this and faucet is mounted onto a brick wall, do I have to remove the brick in order to fix or replace the the damaged component?
    Again, Thanks for your explanation.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    No.
    You need to get to it in the basement or crawlspace.
    If you are on a slab you will have to cut the wall where it is located in the house in order to replace it.
    Do you know how to sweat copper?
  7. adl9413
    adl9413 New Member
    Apr 24, 2006
    Once again Thanks for your replied. No, I don't know how to sweat copper.
  8. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    What better time to learn?
    All you need is a torch, pipe & fitting cleaning brushes, flux, solder, a supportive spouse, and a fire extinguisher, and you're good to go. OTOH, if this is likely to be the only joint you'll sweat in your life, call a plumber. If you promise not to help, he may let you watch, and if he's really a good guy he'll give you a running commentary on what he's doing, which will probably make you happy you called him.
Similar Threads: Woodford Model
Plumbing Forum, Professional & DIY Advice woodford model 12 washer replacement Jun 11, 2014
Plumbing Forum, Professional & DIY Advice Woodford (model 14?) nozzle threading Jun 3, 2014
Plumbing Forum, Professional & DIY Advice Woodford Model 17 vale stem leak Aug 2, 2008
Plumbing Forum, Professional & DIY Advice Leaking Woodford Model 17 Jun 19, 2005
Plumbing Forum, Professional & DIY Advice Woodford 22 hot and cold frostfree faucet Aug 16, 2014
