Woodford faucet problem/question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by CharlieM, May 10, 2008.
  1. CharlieM
    CharlieM New Member
    Jul 1, 2006
    Iowa
    Hello,
    I have a Woodford wall faucet on the house that has a bose bib separate from the valve. (Similar to included link - assuming the link works). It is about 25 years old.
    This year it has begun to "vibrate/hum" a lot when the water is turned on until the valve reaches full open. Anything less than absolute full open, it vibrates/hums. The vibration is enough that the valve handle will actually turn from the vibration. Obviously, this goes through the whole house when the water is running. I realize most of the time valves should be opened fully, but this behavior is new, and sometimes it vibrates even full open. It doesn't seem like air in the line.
    I had a plumber pull the valve assembly, but he could find nothing amiss - seals looked good, etc.
    Any suggestions ?
    http://www.lockeplumbing.com/detail...2&r1=DEW-DPPR000&r2=GRU-595916&r3=FEI-NL9-LED
Similar Threads: Woodford faucet
Plumbing Forum, Professional & DIY Advice Woodford 22 hot and cold frostfree faucet Aug 16, 2014
Plumbing Forum, Professional & DIY Advice Woodford hoot and cold faucet Oct 12, 2012
Plumbing Forum, Professional & DIY Advice Woodford Model 17 Faucet Leaking Apr 24, 2006
Plumbing Forum, Professional & DIY Advice Woodford outside faucet repair May 13, 2005
Plumbing Forum, Professional & DIY Advice woodford model 12 washer replacement Jun 11, 2014
