Woodford 17 Anti-Siphon Hose Bibb
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mwaldon, Apr 20, 2005.
  1. mwaldon
    mwaldon New Member
    Apr 20, 2005
    I just purchased the Woodford 17 hose bibb repair kit, along with a new valve stem assembly. Here's the problem...the end of the old valve stem assemby (including the check valve, valve seat rubber, and retainer screw) fell off the end of the valve stem and is stuck somewhere in the copper pipe. The pipe makes a 90-degree turn just beyond the inside face of the wall, and then another 90-degree turn about 6 inches down, & the water shut-off is +/- 24" in from the wall. Is there any way to fish the pieces out of the soldered copper pipe without cutting/disassembling it? I tried turning the water back on to blow the pieces out & nothing happened/no water came out. Help!
    Woodford 17 Flow Diagram
Similar Threads: Woodford Anti-Siphon
Plumbing Forum, Professional & DIY Advice Woodford 22 hot and cold frostfree faucet Aug 16, 2014
Plumbing Forum, Professional & DIY Advice woodford model 12 washer replacement Jun 11, 2014
Plumbing Forum, Professional & DIY Advice Woodford (model 14?) nozzle threading Jun 3, 2014
Plumbing Forum, Professional & DIY Advice New Woodford sillcock leaking? May 11, 2014
Plumbing Forum, Professional & DIY Advice Woodford series 19 and 25 Jun 17, 2013
