Won't build pressure during / after heavy rain
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Hatchgravel, Apr 15, 2007.
  1. Hatchgravel
    Hatchgravel New Member
    Apr 15, 2007
    Well here's a puzzler, my well works fine most of the time, except whenever we have a very heavy rainfall. Duing those times I've noticed extra sediment in my sediment filter (sand) and the pump frequently has a tough time building enough pressure to reach the 65psi for the pressure valve to shut it off. Fortunately, I can hear when the pump runs so I can shut it off during these times so it won't be damaged. I'm located in South Jersey, near a wetland and our water table is very very high, pratically the surface. My well is 130 ft. and the pump is sitting at 40ft.
  2. Hydrohead
    Hydrohead Junior Member
    Mar 22, 2007
    Pump Contractor
    Great Northwest
    Is the filter before or after the pressure switch/pressure tank?
  4. Hatchgravel
    Apr 15, 2007
    Filter is after the pressure switch
  5. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    Hatch,
    where is the well located and is the top of the casing above ground?
    SAM
  6. Hatchgravel
    Apr 15, 2007
    The well is located about 15 yards from the nearest visible surface water (after all this heavy rain) and about 40 feet from the house. The well casing is about a foot below the surface and capped by a green irrigation box. In looking at it there doesn't appear to be any water coming in over the top.
    What would cause the pump to lose pressure at the house? I figure if the screen on the pump itself were clogged, it would remain clogged even after the rain water subsides and things dry out. This is odd becase the problem occurs only during heavy rainstorms and a day or two afterwards.
  7. sammyhydro11
    Dec 20, 2006
    Massachusetts
    Is this a screened well or a rock well? If its heavy sediment it could be clogging a check valve or any kind of small fitting between the pump and the tank. After a couple of days that sediment could loosen up and then get sent into the filter. Rock holes sometimes have dry zones that dont produce a lot of water until heavy rains. A lot of times these zones have loose silt or sediment in them that get flushed into the well. There is also a good chance that because the well is below grade you are having some surface water intrusion that is carrying some sediment into the well. You might not notice anything when you look at it because maybe the water subsided at that point. I would take a peak at it during a good down pour and see what it looks like. regardless that casing needs to be above ground to prevent any surface contaminants from entering your well.
    SAM
Similar Threads: Won't build
Pumps and Tanks Well Forum & Blog. Water is life. Help! Submersible well pump runs but won't build pressure over 30 psi! Nov 13, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well pump won't build up pressure Aug 23, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet-pump won't cut-out; builds to 48psi, cut-off set to 50psi Jun 19, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Convertible Jet Pump Won't Build Pressure Jul 17, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Well pump pressure switch won't engage Mar 18, 2016
