Wirsbo (Uponor) fitting difference?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Rad777, Apr 20, 2009.
  1. Rad777
    Rad777 New Member
    Nov 6, 2008
    What is the difference between Q4505050 & Q4515050? Respectively Brass Fitting Adapter versus Brass Copper Pipe adapter.
    Q4505050-ProPEX-Brass-Fitting-Adapter
    Q4515050-ProPEX-Brass-Copper-Pipe-Adapter
    The reason I ask for the difference is because I was thinking about how to transition from PEX to Copper -> Valves and/or directly to Valves from PEX.
    Are these fittings something I could just sweat a valve onto?
    Thank you
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    At first glance, the difference I seen was 5 cents :D
    Seriously, the Q4505050 fitting looks like a male sweat fitting meaning it will sweat in to a fitting like a tee. The Q4515050 looks like a female sweat fitting meaning it will sweat on to a pipe.
  4. hj
    Wirsbo
    The male/street one will sweat into a valve, the other solders onto copper tubing which would then be sweated into a valve.
  5. Rad777
    Rad777 New Member
    Nov 6, 2008
    Thanks for the replies & help!
    Still deciding if I am going to Pex all the way to the fixtures/valves, or if I am going to transition to copper and attach it to a stud or a 2x4 horizontally betweeb studs.
  6. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    I would recommend stubbing out with copper. A drop ear fastened to some blocking makes for a very sturdy pipe to connect stops and showerheads to.
    Check out this link for some ideas.
  7. Rad777
    Rad777 New Member
    Nov 6, 2008
    Thanks for the recommendation and the advice. I read a few posts by Terry mentioning that practice as well and I think that is what I will use/do.
    Thanks
Similar Threads: Wirsbo (Uponor)
Plumbing Forum, Professional & DIY Advice Wirsbo ProPex Expander Tool & Pex-A - Question Aug 6, 2016
Plumbing Forum, Professional & DIY Advice Replacing Wirsbo Control Type 514 with Uponor A3031004. Feb 5, 2015
Plumbing Forum, Professional & DIY Advice Wirsbo/Uponor PEX & future work Feb 21, 2013
Plumbing Forum, Professional & DIY Advice Installing Wirsbo PEX, have some install detail questions Oct 10, 2012
Plumbing Forum, Professional & DIY Advice Wirsbo PEX question Oct 8, 2012
