Wiring Trouble
Discussion in 'Electrical Forum discussion & Blog' started by jperna, Nov 13, 2007.
  1. jperna
    jperna New Member
    Nov 13, 2007
    HI all, i am replacing a switch with a dimmer, the room currently has track lighting, and recently added 2 high hats, all on the same circuit. My problem is that i have 3 black wires to attach and only 2 black wires on the dimmer. I also bought a 3 way switch, but that didn't seem to work either, Any suggestions?
  2. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    CAUTION. YOU MAY DIE
    Could be a number of scenarios. You will need a voltage tester or work it hot and touch some stuff together.
    Is there another switch that also contriols the lights?
    If not, it is likely that one of the 3 wires will be hot and the other two will be switch legs going to the track and the added cans.
    All a switch does is connect the hot wire to the switched wire. If you touch the hot to the switch leg, it will spark and the light will come on.
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    What are you trying to attach to what??? Telling us you "have 3 black wires" does not do us much good if we don't know where they go and what they control/feed.
    Can you tell us how the old switch was wired?
  5. hj
    wires
    If the dimmer only has two black wires then one is the feed and the other is the load. As far as which wires each of them attach to, that depends on what the three black wires do, and that we cannot tell you without testing them. AND if you have three way circuit, you probably need three way dimmer, and if you do not then you cannot use a three way switch.
Similar Threads: Wiring Trouble
Electrical Forum discussion & Blog Dishwasher wiring all of a sudden overheats and melts Feb 27, 2017
Electrical Forum discussion & Blog Underground UF Wiring Gauge Selection Feb 22, 2017
Electrical Forum discussion & Blog Wiring Split 15 & 20 amp circuits on same receptacle Feb 22, 2017
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Strange Dimmer Switch Wiring Jan 6, 2017
