Wiring question for bathroom light/fan
Discussion in 'Electrical Forum discussion & Blog' started by Brian.Hoard, May 26, 2011.
  1. Brian.Hoard
    Brian.Hoard New Member
    Nov 21, 2010
    Haymarket, VA
    Hi,
    I'm remodeling a powder room and installing a new ceiling light/fan. I have all the wiring in and connected and before I turn the breaker on, I wanted to ohm out my wiring to be sure there are no shorts. Since getting all the wiring tucked in the fan box was tough, I don't want to have a short in there.
    So I'm surprised to see that my wiring, the neutral wiring is showing 0 resistance to ground and the box metal housing. Not sure if this is normal or not. The black/hot wires don't read to ground, but the white/neutral ones do. Is it okay to turn on the breaker? Is it normal for neutral to have 0 resistance to ground?
    Thanks for any help.
  2. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    That's normal. The neutral and ground wires are connected together at the main panel. This is the only point in the system where the neutral should be tied to ground (don't connect neutral to ground in any of your boxes, etc.).
  4. jadnashua
    I'm surprised it is zero ohms, but it should be a small number. The wire itself has some resistance depending on its length and gauge, but definately should be close to zero.
    If you are using the audible 'short' warning, it will trigger at a low reading, but does not necessarily mean zero. Then, many low-cost meters aren't all that accurate, either.
Similar Threads: Wiring question
Electrical Forum discussion & Blog Question about Ceiling Fan wiring Nov 9, 2016
Electrical Forum discussion & Blog Questions on old wiring stapled to bottom of joists Apr 16, 2014
Electrical Forum discussion & Blog Wiring Questions For Small Bath Remodel Oct 9, 2013
Electrical Forum discussion & Blog ceiling fan and wiring questions Jul 15, 2013
Electrical Forum discussion & Blog Random electrical wiring questions May 27, 2013
