wiring path for lights
Discussion in 'Electrical Forum discussion & Blog' started by samlin7, Jan 10, 2008.
  1. samlin7
    samlin7 New Member
    Dec 26, 2007
    Can someone confirm if this is correct sequence of wiring
    14/2 cable (power source) into light fixture 1
    14/3 From light fixture to a 4 gang switch box
    In that switch box will be a switch to light fixture 1
    There will be 3 other switches in that switch box - a 14/2 going to light fixture 2 and a 14/2 going to light fixture 3 and a 14/2 going to an outdoor receptacle for holiday lights.
    Is that the correct wiring sequence?
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    That sequence can be wired to work as you wish.
  4. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    If it was me wiring it, I would go to the switch box first, pigtall the hot the the 4 switches, then run the 14/2 to each light fixture.
    It will work the way you have it listed also.
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Me too, but for some reason I thought the 1st light outlet was already wired.
  6. samlin7
    samlin7 New Member
    Dec 26, 2007
    yeah i guess i can do that, actually that was my original thought, but i was trying to be creative with less cables going into the switch box. Your way would have had
    (1) 14/2 From power to a 4 gang switch box
    In that switch box will be a switch to light fixture (2) 14/2
    There will be 3 other switches in that switch box - a (3) - 14/2 going to light fixture 2 and a (4)14/2 going to light fixture 3 and a (5)14/2 going to an outdoor receptacle for holiday lights.
    5 total 14/2 to that box
    My original request would have had 3 14/2 and 1 14/3 into that switch box
    3 total of 14/2 and 1 total 14/3 in that box
  7. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Electrically, the two methods are identical. Aesthetically, most electricians would prefer that the supply cable come into the switch box. I don't know if the Code has anything to say about it.
Similar Threads: wiring path
Electrical Forum discussion & Blog Need help wiring ceiling fan! Wednesday at 6:14 PM
Electrical Forum discussion & Blog Strange Dimmer Switch Wiring Jan 6, 2017
Electrical Forum discussion & Blog Doorbell Wiring Dec 29, 2016
Electrical Forum discussion & Blog Advice for wiring 2 baseboard heaters Dec 16, 2016
Electrical Forum discussion & Blog Question about Ceiling Fan wiring Nov 9, 2016
