Wiring Help for 2 Outlets (One on a Switch)
Discussion in 'Electrical Forum discussion & Blog' started by molo, Sep 27, 2009.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    The power comes in to a box with 2 outlets. The goal is to have one of the outlets on a switch. The switch is not in the same box (6 feet away from outlets). Does this require 3 wire to the switch?
    Thanks for any replies
  2. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    No, it can be done with 2 wire.
    Remark the white wire red or black and connect it to the incoming hot wire.
    Connect the wire to one side of the switch, and take the black wire back to the receptacle, break the tab and connect the wire to the top or bottom half.
  4. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Will this make only half of the outlet switched or the entire outlet? There are 2 outlets and we want one switched and one not switched.
  5. jadnashua
    There are tabs between both the neutral screws and the hot screws. Leave the neutral tab intact. Put a pigtail on the incoming hot lead, break the tab on the hot side, run the hot lead to the outlet you want to be always hot, and the switch leg from the switch to the other. The other wire from the new 2-wire cable to the switch gets connected to the pigtail to provide the hot.
Similar Threads: Wiring Help
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Ceiling fan wiring help Feb 22, 2015
Electrical Forum discussion & Blog Need Help Wiring Relay for Bathroom Timers Aug 13, 2013
Electrical Forum discussion & Blog Help with strange light fixture wiring Apr 15, 2013
Electrical Forum discussion & Blog Help with wiring diagram Feb 25, 2012
