Wiring heating system pump
Discussion in 'HVAC Heating & Cooling' started by alternety, Mar 4, 2007.
  1. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    I have one pump in the radiant heating system that does not have a big enough entry hole to attache the wires with 3/8" flex conduit. It is equipped from the factory with plug-in cord.
    The pump is not controlled via switching the 120V line. It is a remote sensing variable speed pump.
    Is it allowable to simply put an AC power box near it and plug the pump in?
  2. jadnashua
    If it has an a/c plug, my guess is there should be no problem just plugging it in. As is true with most of these pumps, the bearings are usually water cooled/lubricated - don't run it until the thing is sitting in the pipe and water filled.
Similar Threads: Wiring heating
HVAC Heating & Cooling terms in a hot water heating system and help needed on wiring Nov 6, 2014
HVAC Heating & Cooling Honeywell 3210D Wiring Oct 22, 2016
HVAC Heating & Cooling Wiring issues Aug 13, 2016
HVAC Heating & Cooling Wiring diagram for furnace relay & thermostat common wire May 26, 2016
HVAC Heating & Cooling Help with adding common wire (with wiring diagram) Jan 10, 2016
