Wiring for boat lift motor
Discussion in 'Electrical Forum discussion & Blog' started by FlaMike, Feb 12, 2010.
  1. FlaMike
    FlaMike New Member
    Feb 12, 2010
    FL
    Motor is currently serviced by 12ga romex which I do not believe is enuf for the long run out the dock.
    I have a new circuit, 50amp breaker, 8ga stranded copper, to start from the house. We are looking at 700ft from the panel to a 1 hp motor which draws 13.4amps @ 115v. I plan to run wiring in PVC. Questions: do I have to use #8 wires or could I use #10 with a #12 ground? Does stranded vs solid copper make any difference?
  2. jadnashua
    Some motors can be rewired to run at either 110 or 220vac. If yours can, consider rewiring it for 220. The voltage drop would be less, allowing you to run smaller wires. See what the pros have to add.
  4. Lightwave
    Lightwave New Member
    Aug 20, 2007
    Vancouver, BC
    To be frank, if you have to ask about hooking up #10 to a 50 amp breaker, then you don't have the background to do this job safely. Please call an electrician before you hurt someone.
    When it comes to wiring marine equipment at extreme distances, what you--and most non-pro message board participants, including myself, don't know--can very easily kill you. In addition to the minimum safe wire size for your breaker, you also need cable intended for use below ground (in PVC), you need to deal with the voltage drop issue somewhow, you need to meet requirements for motor overcurrent protection and service disconnects, and you need to address grounding and GFCI issues specific to dock equipment. #8 wire probably won't burn up under fault current held by a 50A breaker, but it won't address any of the other issues.
    Call a pro.
    I suspect the easiest solution may be to use a portable generator.
  5. FlaMike
    FlaMike New Member
    Feb 12, 2010
    FL
    THANKS!.... agree a portable generator is best solution.... saves $$ and many hours in the wetlands and needed one anyway for outages.
  6. codeone
    codeone Code Enforcement
    Sep 5, 2008
    Code Enforcement, Instructor
    North Carolina
    NM cable nor UF cable are approved for use on at or going to boat docks! Call an electrician!
  7. alfredjoaquin
    alfredjoaquin New Member
    Feb 25, 2010
    UK
    Before repairing it, I think it needs a lot of experience for giving a connections.So i would suggest you to go for a good electrician.
  8. skdaddle
    skdaddle New Member
    Jul 30, 2011
    sc
    It may be possible to get your local power company to install a meter pole closer to your dock, where you could install a panel box with GF breakers for the dock system. 700' is a long way.
  9. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    skdaddle, you do realize this thread is well over a year old......
  10. skdaddle
    skdaddle New Member
    Jul 30, 2011
    sc
    Ha, it sure is! I am also well under a few days new to this site, still have lots to learn about navigating it, thanks!
Similar Threads: Wiring boat
Electrical Forum discussion & Blog Dishwasher wiring all of a sudden overheats and melts Feb 27, 2017
Electrical Forum discussion & Blog Underground UF Wiring Gauge Selection Feb 22, 2017
Electrical Forum discussion & Blog Wiring Split 15 & 20 amp circuits on same receptacle Feb 22, 2017
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Strange Dimmer Switch Wiring Jan 6, 2017
