Wiring a jet pump in conjuction with a storage tank
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Terrasmooth, Jul 3, 2012.
  1. Terrasmooth
    Terrasmooth New Member
    Jul 3, 2012
    Northern Arizona
    Hello,
    I have a 3/4 hp jet pump that I want to use to pump water from my storage tank to my pressure tank.
    I have the high and low floats for the storage tank, I need a wiring diagram to wire this setup. Do I need a control box for the jet pump?
    www.terrasmooth.com
  2. hj
    The switch for the lower float has to open when the float drops and the upper one has to open with the float rises to fill the tank. You can wire them in series to control the pump's operation, Once it is full you only need to wire the lower one to stop the pump when the storage tank runs out of water, but you also need a controller to tell the pump when the main tank needs water.
Similar Threads: Wiring pump
Plumbing Forum, Professional & DIY Advice Sump pump wiring Aug 31, 2011
Plumbing Forum, Professional & DIY Advice wiring for deep water submersible pump May 28, 2011
Plumbing Forum, Professional & DIY Advice $5800.00 to replace the well pump and wiring Apr 13, 2011
Plumbing Forum, Professional & DIY Advice Garbage Disposal Replacement Wiring Aug 23, 2015
Plumbing Forum, Professional & DIY Advice old ceiling wiring for fan installation Jul 18, 2015
