Wire and pipe broken off well pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by chrd00, Jun 16, 2012.
  1. chrd00
    chrd00 New Member
    Jun 16, 2012
    PA
    After no water pressure and power inside, went out to the pump. wires broken and no pipe either. Any thoughts on how to get the pump out..or could we leave it in and put in a new pump?
  2. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    You may not want to hear this, But You need a well Pro. Good luck
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Maybe you got lucky and someone stole your pump. A little more info would help but as toolaholic mentioned, you need a pro before you make a bad situation worse. This is no time for DIY.
  5. ballvalve
    Dec 28, 2009
    northfork, california
    If its deep enuf and the lost pumps not new set a new one a few feet over the old one.
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I'm going on the assumption that the pipe broke off at the top and that there is now a lot of pipe sticking up above the pump precluding the OP from setting a new pump a few feet over the old one.
    Now assumptions are all we have to go on since the OP makes no mention of the size of casing, depth of well, pitless or sanitary seal, etc. Maybe he got lucky and the pump unscrewed itself from the bottom of the pipe, and all the pipe is still hanging from the pitless.
  7. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    Well ,You could have someone run a camera down the casing, and try fishing with a snear. You would need to disinfect the camera head and cable 1st
    Also disinfect Your well after. Folks in the well business have past experience with this and are invaluable to You. Also, If You can find a well Pro with a camera, it may only have been used ,in wells only and be clean . Good luck
  8. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I have heard everything now.
Similar Threads: Wire pipe
Pumps and Tanks Well Forum & Blog. Water is life. 11 yr old drop pipe and wire reusable on 220ft pump swap......? Apr 9, 2012
Pumps and Tanks Well Forum & Blog. Water is life. submerssible PVC pipe and electrical wire fallen down Jul 27, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Lost pump wires down the well help Jan 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. White paper: measuring 3-wire pump resistances with unknowns Nov 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Installation costs/10/3 wire specs-good? Aug 4, 2016
