wiped joint
Discussion in 'Toilet Forum discussions' started by cwhyu2, Aug 31, 2007.
  1. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Has anyone done wiped lead joint to a brass furele?
    Pardon the spelling.
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Why would you want to solder a brass ferrule in a compression fitting?
    It is true that the ferrule is what seals a compression fitting and not the threads, but you can seal even an old used ferrule with pipe compound or teflon tape. No need to solder it.
    If you're going to solder something, it would best be fittings made for that purpose.
    Mike
  4. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    He didn't write anything about soldering a ferrule in a compression fitting.
    Why do you assume that is what he was asking?
    What cwhyu2 asked is:
    I've seen this but I have never done it myself. Lead "wiping" is a lost art theses days.
  5. jimbo
    jimbo Plumber
    The brass ferrule he is talking about is NOT the compression ferrule we immediately think of today. Lead work is certainly a lost are out here. Never saw any lead personally, except the tons we used to have to unload out of the AUX Tank when taking on a full load of warshot torpedoes. Sorry, some things you just never forget about!!!
  6. hj
    wiped
    The last wiped joint I did was for my journeyman's test in 1955.
Similar Threads: wiped joint
Toilet Forum discussions What toilet do I need to push solids about 15ft to pass a joint in pvc sewer line Oct 31, 2015
Toilet Forum discussions Pressure assited toilets: best supply pressure and outflow pipe joint stress Aug 27, 2015
Toilet Forum discussions leaking ABS closet flange joint Mar 24, 2007
Toilet Forum discussions Large Brass (or Chrome-Plated) Slip Joint Nuts Jan 21, 2007
Toilet Forum discussions leaking joint @waste pipe & closet flange Sep 24, 2006
