Wing-its and grab bars
Discussion in 'Shower & Bathtub Forum & Blog' started by jadnashua, Jan 25, 2007.
  1. jadnashua
    Has anyone used Wing-its? www.wingits.com If so, do you think they really are worth the expense?
  2. jimbo
    jimbo Plumber
    I am very familiar with the wingits set used to install the brackets for the new curved shower rods. They are specially made for that, and can speed up the job considerably. They do require a 3/4" hole, slightly larger than would be necessary for a conventional toggle bolt.
    I have seen the large ones designed for grab bars. They require a large hole, and at about $25 each I just can't justify the cost.
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Looking to install a LED Grab Bar.
    Can the Wingits work with any Grab Bar?
    Here is a new LED Grab Bar I just powered up...
    The bar is made by ITC or Elio...
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  5. jadnashua
    It's hard to tell for sure, but it looks to me that the flange on that bar is smaller than the Wing-Its diameter, so no, I don't think so. They do have a line drawing on their site where you could tell. The holes are threaded and in a fairly common pattern, but once installed there is NO play...if you don't get it where you want it the first time, you're stuck, since there's only the hole slot in the bar to accommodate any error. Most bars don't have slots, either, so it's be exact.
  6. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    I have heard many good things about these Wing-Its over the past couple of years.
    I want to install some and do my own testing with them. The Standards are tough up here in Canada and in our Health Care facilities - even tougher.
    What do you think of the light?
    JW
  7. jadnashua
    The bar is certainly different. I have some overhead lights in my tub/shower. Depending on the light output, they might be useful...I'd have to see it in person. Hard to tell the construction quality or the quality of the materials. Where does the low-voltage supply go and how do you turn it on and off?
Similar Threads: Wing-its grab
Shower & Bathtub Forum & Blog Adhesive for ceramic soap dish/grab handle in bathtub? Oct 6, 2016
Shower & Bathtub Forum & Blog Backer board for shower grab bar (fiberglass surround) May 9, 2013
Shower & Bathtub Forum & Blog Need help removing grab bar from bathtub Sep 2, 2009
Shower & Bathtub Forum & Blog tub grab bar Dec 15, 2006
Shower & Bathtub Forum & Blog Installing a grab bar into a fiberglass shower Nov 2, 2005
