Will this venting work?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Need-To-Know, Mar 18, 2013.
  1. Need-To-Know
    Need-To-Know New Member
    Mar 18, 2013
    Florida
    Hi, Great and helpful forum. Thanks! I ran my supply from what I learned here. :)
    I am replacing the drainage now and I am wondering if this looks like it would work or if I need to add more venting to the shower drain?
    Newbie to drainage.
  2. Terry
    Aug 17, 2004
    With a 4" stack the way it's run you're plenty good.
  4. Need-To-Know
    Mar 18, 2013
    Florida
    Excellent - thanks buddy! Back to work and will have it installed before the night is out. :)
    Can't thank you enough!
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    It depends on trap to vent distance and you can't waste stack vent bathroom fixtures.
  6. hj
    quote; It depends on trap to vent distance and you can't waste stack vent bathroom fixtures.
    I don't know what THAT means, but we ALWAYS "stack vent" bathroom fixtures, at least on the upper level. As long as that top 1 1/2" is for a sink and it is within the prescribed limits for a trap you are okay. You probably also only needed a 3" riser, assuming this is not the lower level of a two story building, but if there is a bathroom above it, then everything we said is invalid. I am not sure why the second image since the only difference is that it does not show the septic connection.
  7. Need-To-Know
    Mar 18, 2013
    Florida
    Actually that drawing is somewhat the right perspective. The underneath (horizontal brown line) in the drawing is the floor then crawl space under the house and the top goes thru the roof. I am coupling to old case iron that I cut. Cast thru the roof and cast after the bottom 90 - then out to a septic tank.
    Sink trap to vent goes thru the wall then another 90 is the only thing left out. It is about 3 feet max to the 90.
    This is the previous setup and never had problems. But in saying that nothing in the house was built to code. I have had to gut it and rebuild everything.
    Yeah sorry about the second image....I added the septic and guess did not properly remove the other image....Senior moment...
  8. Sunny1020
    Sunny1020 New Member
    Apr 26, 2013
    Port angeles wa
    Just curious need to know, what program did you use to generate the image of your venting system?
Similar Threads: venting
Plumbing Forum, Professional & DIY Advice Is my venting adequate for what I have Mar 21, 2017
Plumbing Forum, Professional & DIY Advice Venting question on a double lav on outside wall. Mar 21, 2017
Plumbing Forum, Professional & DIY Advice Venting Saniflo. Much confusion Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Proper venting of washing machine and sink drain in basement Mar 13, 2017
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Feb 24, 2017
