Will this tub vent? Pic attached!
Jpb116
Massachusetts
Please bear in mind that the vent tube will be tied into the vent for the shower going through the roof.
Construct30
NorthWest PA
That is not a proper tub hook up. The vent is connected after the trap, not before, I see no trap on your install. You need to do a bit more research on traps and vents.
gmt
Pennsylvania
It'll vent... It will vent sewer gases inside the home.
Where is the trap below the drain? I'm sure someone here has a picture to post of the proper way (I have nothing readily available)
Jpb116
Massachusetts
trap...
The trap is below the drain. This setup is above the floor, the p-trap is below the floor between the joists.
Jpb116
Massachusetts
position relative to the trap.
So it's not proper to vent before the trap? That's good info, and the reason for my pic and question...
