Will old well pump water?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by RMARTIN, Jul 9, 2011.
  1. RMARTIN
    RMARTIN New Member
    Jul 9, 2011
    Texas
    Last year I bought a 10 acre place with a 2002 built house. It has co-op water now but in the front yard was a well, tank and all the needed fittings in a small pump house. Previous owner had it since 2003 and has used the co-op water, and didn't know anything about the well. I think there was a older home here before. All the hardware looks to be 10-15 years old. I took everything off of it to tear down the pump house (only 3 feet high and was an eyesore). Now I want to try and see if it will pump and if so use it for irrigation. So it's got a 4 1/2" sch 40 pvc casing coming out of a 3x5 ft slab. A 1" pipe out the top of the head and a 3 wire 12 gauge submersible pump wire, black, yellow, and red. The output pipe after the tank then goes into the ground and a larger buriable-type 3 wire 6 gauge goes into the ground. About 10 feet away the wire comes back out of the ground and is coiled up. Have no idea where the wire or the pipe goes to. Anyway how can I tell if it's 110 or 220 and how would I test it to see if the pump will work? The head doesn't look like it's ever been opened. No idea how deep it may be. On the front of the property is another old pump house. The pipe has been pulled and is laying against a fence, looks to be about 60 - 80 feet long. Not sure if that's an indication of how deep this well might be. Any ideas?
  2. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    There should be a control box and a pressure switch somewhere. The pressure switch should have contactors connected to 230V with a line going to the c-box. Apply power to the pressure switch, make sure the contactors are closed, and apply power to the c-box. If it pumps water, I'd say you're in business.
    Be careful of electricity, if you don't know what you're doing, call a pro. Also I would keep your well on the down low, in some areas with city water they will make you plug and abandon any old wells.
  4. RMARTIN
    RMARTIN New Member
    Jul 9, 2011
    Texas
    I disconnected everything last year. I just have 3 wires coming out of the head and not sure if it's 110 or 220.
  5. Texas Wellman
    Feb 9, 2010
    SE Texas-Coastal
    Most likely it's 220. If it's a 3-wire pump, you will need a control box to start it. Sounds like it's the old 3-wire, newer ones have a ground also.
    Try a 1-HP box and see if it will start.
Similar Threads: pump water
Pumps and Tanks Well Forum & Blog. Water is life. Pump runs continuously while water is on. Mar 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water Not Flowing Into House, Is It The Pump? Feb 24, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pump stopped. Short cycles then stops. Jan 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Stand Alone Water Tank & Pump: Jan 4, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Power for water treatment injection pump Nov 9, 2016
