will NPT fitting work with IPS fitting?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rick.a, Apr 13, 2011.
  1. rick.a
    rick.a New Member
    Jan 11, 2007
    Palmer, Massachusetts
    Are these 2 standards the same? Or do they have different taper, or thread count or pitch? I tried to look this up but got more confused than ever. I now know what they stand for, but will they fit together properly and not leak. Using 3/4" brass fittings.
    thanks,
  2. hj
    You have to define whether "IPS" means "iron pipe size" or "iron pipe straight" thread
  4. jimbo
    jimbo Plumber
    In most contexts, we are talking about the same thing. NPT refers to National Standard Pipe Thread Tapered. IPS is not a stricly technical term, or at least it doesn't refer to threads. It stands for IRON PIPE SIZE, so really refers to pipe ID and OD. In most contexts, we use IPS in referring to NPT ( tapered) threads, although there are plenty of applications in daily use where the threads are NPS ( National Standard Pipe Thread Straight).
    Now you know why plumbers mumble to themselves in their sleep!
  5. BenWara
    BenWara New Member
    Oct 30, 2010
    South Dakota
    per the 27th edition of the Machinery's Handbook, NPT refers to American National Standard Taper Pipe Thread. :)
  6. rick.a
    rick.a New Member
    Jan 11, 2007
    OK, thanks.
Similar Threads: fitting fitting
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
Plumbing Forum, Professional & DIY Advice What fittings are there for polybutylene pipes? Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Uponor PEX with non-ProPEX fittings Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Viega press fittings for PEX Sep 12, 2016
Plumbing Forum, Professional & DIY Advice Spinning PEX fittings Sep 3, 2016
