SVWillow
Remodeling bathroom, want to place the walk-in shower’s valve (thinking of using a Moen Model 3510 Meontrol) on wall opposite the shower head. This will entail about a six foot run of ½” CPVC with 4 or 5 90 degree elbows between valve and shower head. Inputs are two ½” CPVC lines (hot and cold) using ½” IPS adapters.
Moen suggested using the Tub outlet rather than the Shower outlet. Apparently this would require some changing around the guts, in order to keep the hot, cold and volume compatible with the trim.
Does all this make sense? Should I turn the valve upside down and plumb to the shower head from there? Would running ¾” from the valve outlet to the shower head gain me anything? (I know I’d have to find the proper size adapters at both ends) And can anybody give me step by step instructions as to what needs to be done to the valve guts so that cold is cold and hot is hot, etc.?
Once again, Much thanks for any help,
