will low flow toilet work on old septic system?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Ten High, Mar 3, 2012.
  1. Ten High
    Ten High New Member
    Jan 10, 2011
    Upstate New York
    Theoretical question:
    Have a 1950s (6gallon?) toilet (Crane) on even older septic system. I am wondering if a modern 1.6 gallon toilet will work with this old system. here's the existing setup:
    From upstairs toilet, waste pipe has a vertical drop of about 12 feet to right angle turn , then pipe goes horizontal about another 12 feet to another right angle turn, then a horizontal straight run of almost 30 feet out of the house and continuint straight another 20 feet or so to the concrete septic tank . Its about a 1930ish system.
    Just wondering, if I replaced the old fashioned toilet, if the new modern low flow toilet would have enough water discharge to flush things out to the septic tank ?
    The existing system as is works fine and always has, but eventually want to put in all new bathroom fixtures.
  2. Terry
    Aug 17, 2004
    With that distance it will be fine.
  4. hj
    The toilet does NOT care where its waste is going. If it will work with a 100' line to a city sewer, it will work for a septic tank.
  5. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
  6. Ten High
    Ten High New Member
    Jan 10, 2011
    Upstate New York
    Everyone, thank you for the answers. Will check out the modern fixtures knowing this.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Just keep in mind, low flow toilets are not equal. Do heed the advice on Terry's web site.
Similar Threads: flow toilet
Plumbing Forum, Professional & DIY Advice While I'm draining the tub if I flush the toilet the toilet almost overflows? Feb 12, 2015
Plumbing Forum, Professional & DIY Advice Strange contraption: Toilet flapper built into middle of overflow tube Jun 11, 2014
Plumbing Forum, Professional & DIY Advice Need recommendation for Low Flow toilet, showerhead, and aerator for apartments May 15, 2014
Plumbing Forum, Professional & DIY Advice just broke my toilet trying to fix it :( overflowing => breaking the water fill valve Mar 13, 2014
Plumbing Forum, Professional & DIY Advice Toilet Back Flow Preventer May 9, 2013
