will installing two water heaters work
Discussion in 'Water Heater Forum, Tanks' started by dichroic, Oct 3, 2013.
  1. dichroic
    dichroic New Member
    Oct 3, 2013
    Oregon
    hello, and thanks for this forum.
    I have a small cabin I wish to rent. It has a 20 gallon, 110 water heater that is fine for two people. I would like to install a second 20 gallon 110 water heater next to the shower, which is only 15 feet away. Will I then have 40 gallons of hot water if I connect it into the existing plumbing lines? I don't want to have 2 separate zones, just one zone with 2, 20 gallon water heaters for a total of 40 gallons. If I separate it into zones I still only have 20 gallons going to the shower. I want the shower to use both water heaters at the same time. Will this work? I really don't want to have to install a 220 volt water heater if I don't have to. Thank to anyone who can let me know if my idea will work.
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    If cold-input to the water heater by the shower is plumbed to the hot-output side of the original HW heater you'll get the full showering capacity out of it. If you try to parallel them by tying the hot outputs together, probably not. Shbrt draws from the tank by the shower will have a small "abandoned heat" penalty of water drawn from the first tank ending up in the plumbing between them, but that can be mitigated by insulating that line well (R4 minimum, not the crummy 3/8" wall R2 stuff sold at box stores.)
  4. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    How ever you do it make sure that your Cabin can support the extra electrical load.
    Cabins are not known to have large electrical systems.
    Are we getting spoiled yet ?
    Good Luck.
  5. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    Often in hotels or restaurants there will be multiple hot water heaters. In most cases all the tanks are located in one room. The cold line goes to a tee and then splits to go to each tank. The hot outlets go to another tee so that there is one hot line. In these set-ups there are unions and valves so a heater can be removed and replaced or worked on etc without a big impact on the hot water.
    I your case it might be cheaper and easier to just replace the 20 gallon heater with a 40 gallon heater.
  6. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I agree.
    You could use 120V elements, and would not need all of the extra headaches.
    Have Fun.
  7. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    I suspect that were there space for a 40 gallon tank, there would already be one...
    Most 120V 20 gallon water heaters are set up with elements to work on a 20A breaker.
  8. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I bet you are correct.
    Cabins are not like living in the hotel, and some heaters are put under the floor. Very little head room.
    Can I say Spoiled again ? Oops, just did.
    Have Fun Everyone.
  9. dichroic
    dichroic New Member
    Oct 3, 2013
    Oregon
    thanks everyone. yes the cabin is small and the current wh is in the kitchen next to the sink. it's the old modular steel kitchen insert from the 50's. looks like the best thing is to install a 40 gallon one and by pass the 20 entirely. I have a 50 amp stove breaker that is free as I have a gas stove. Taking out the 20 gallon will give me that breaker free also. Should have plenty of power. Can I just cap off the cold going to the current 20 and tap into the cold for the new 40 about 15 feet away?
    thanks again
    donald
Similar Threads: installing water
Water Heater Forum, Tanks Installing new Phoenix water heater, expansion tank too? Mar 12, 2016
Water Heater Forum, Tanks Installing a new water heater Jul 28, 2015
Water Heater Forum, Tanks Installing an electric water heater in series with boiler Apr 17, 2013
Water Heater Forum, Tanks Installing new Electric Water Heater, questions Jan 12, 2012
Water Heater Forum, Tanks Installing pipe from water heater tank to a laundry machine Oct 27, 2010
