will extreme cold harm toilet?
Discussion in 'Toilet Forum discussions' started by macska, Apr 18, 2005.
  1. macska
    macska New Member
    Dec 31, 2004
    I bought a toilet last fall, with the full intention of installing it at the time. That did not happen and the toilet spent the winter (in Massachusetts) in an unheated garage. Is this something that might damage the toilet, like casue an internal crack that would not be visible? I don't want to take any chances so I'll buy a new toilet if necessary.
    Macska (pronounced Much-kah)
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    There would have to be water inside of the bowl or tank in order to cause internal cracking. If it is in a dry area, there will be no harm to the toilet.
  4. macska
    macska New Member
    Dec 31, 2004
  5. Stu L.
    Stu L. New Member
    May 4, 2005
    New York, NY
    While cold temperatures will not harm a toilet that is in storage and dry, cold temperatures can definitely harm your butt when you sit on a freezing toilet. If you sit on a freezing toilet directly out of the bath, your butt could stick to the seat much like your tongue would stick to a frozen aluminum lightpole. I once took a stinking dump into the frozen surface water of my cabin toilet, thinking that my steaming logs would melt through and everything would be ok. The melt-through definitely occured, but my supply pipe was also frozen. As cold as it was, I had to open the window to air out that badboy. Thank you.
  6. hj
    IF there was water in it then it could definitely freeze and crack, and since only prisoners and people using antivandalism toilets normally sit on a "metal" seat I think you are safe from being caught in an embarrassing position.
Similar Threads: extreme cold
Toilet Forum discussions Tankless Toilet extremely loud Mar 13, 2013
Toilet Forum discussions Brand new Toto Drake 2 piece - extremely weak flush, any ideas? Jun 30, 2012
Toilet Forum discussions Hot/Cold Reversed; Kohler Shower Valve Mar 2, 2006
Toilet Forum discussions flushing toilet rattles cold water pipe May 17, 2005
