will caulk job cure?
Discussion in 'Shower & Bathtub Forum & Blog' started by dl21, Jul 5, 2012.
  1. dl21
    dl21 New Member
    Jul 5, 2012
    seattle
    Hi,
    I just had my new shower (no tub) caulked. My contractor used silicone caulk (latasil), and I know that the shower was completely dry before caulking. The problem is that the shower was accidentally used for a 10 minute shower 4 hours after my contractor had finished, and then, once again for another 10 minutes, the next day. After the second shower, I figured out my son had used it (he vopletely forgot I had told him NOT to use the shower for 2 days :) I dried the seams (that had been caulked) with a towel and it has not been used since. It has been 2 days since it was used last.
    When I press on the caulk, it feels somewhat soft, but does not feel sticky or tacky. My question is, do you think it will cure OK, and is there a way I can test the caulking to see if it is Ok, or what should I look for?
    Thanks!!
  2. jadnashua
    Some caulks can take up to a week to cure completely, but are generally skinned over in a short time. If the bond was not broken to the tile, and especially if you have porcelain tile that doesn't absorb much of any moisture, you may be okay. You might want to call the manufacturer's help line and ask them.
  4. dl21
    dl21 New Member
    Jul 5, 2012
    seattle
    Thanks so much Jim. It is porcelain! Yipee. I need all the help I can get:) Great idea to call the manufacturer. Thank You!
Similar Threads: caulk cure
Shower & Bathtub Forum & Blog Procedure for No Caulk Shower Drain Oct 2, 2016
Shower & Bathtub Forum & Blog Shower door rail has openings INSIDE the shower? Ruining caulking. Feb 20, 2016
Shower & Bathtub Forum & Blog Caulking around trim sleeve? Feb 13, 2016
Shower & Bathtub Forum & Blog Help, shower leaking around tile and caulking gap Dec 26, 2015
Shower & Bathtub Forum & Blog oh boy... caulk over grout -- oh no Sep 30, 2015
