Will a seldom used trap dry up?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by MushCreek, May 18, 2013.
  1. MushCreek
    MushCreek New Member
    Apr 30, 2013
    Travelers Rest SC
    In our new house, I am building a basement bathroom which will only see light use. I'm putting in a bath tub because I feel there should be one in the house. The master bath only has a shower. The tub may NEVER get used. At the least, it could go a year or better without use. Can the trap dry out from sitting that long? How would you prevent this? Would a plug work, or will it eventually dry out from the other side? Or should I schedule running water in it periodically, like changing smoke detector batteries?
  2. DougB
    DougB Member
    Jun 19, 2010
    Software Developer / Engineer
    Minneapolis - Land of 10,000 taxes
    The water in the trap will eventually evaporate. After the trap is filled with water, add some mineral oil. It will float on top of the water and will not evaporate.
  4. hj
    The trap is exposed to air on BOTH sides of the "J" bend, so mineral oil on the "inlet" will not prevent evaporation on the outlet side. Pour recreational vehicle antifreeze into the drain, and replace it anytime you flush water into the tub. A trap will go dry in a matter of weeks, not months or years, if not used.
Similar Threads: seldom used
Plumbing Forum, Professional & DIY Advice Clogged toilet caused major flooding Jan 14, 2017
Plumbing Forum, Professional & DIY Advice Whole House Water Filter HELP...super confused Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Where can backwater/backflow valves be used in a building? Nov 29, 2016
Plumbing Forum, Professional & DIY Advice How to sell an unused plumbing item? Jul 17, 2016
Plumbing Forum, Professional & DIY Advice Flushing Toilet, Coming Through Shower Drain... Only When A Lot Of Water Is Used Apr 25, 2016
