Wilkins PVB leaking bonnet
Discussion in 'Irrigation / Sprinkler Forum' started by MANewland, Jun 2, 2005.
  1. MANewland
    MANewland New Member
    Jun 2, 2005
    Computer tech
    Louisville, CO
    The system is as follows: 5/8" meter - 70psi - 3/4" PVB to a 1" PVC mainline to Orbits manifold (I told my friend to get Rainbird valves and I would build him a manifold) - way under 15GPM per valve; With the mainline under pressure there are no leaks. When he opens a valve, the PVB has water draining from the bonnet area and there is not enough pressure to fully operate Rainbird popups (they spray only a foot or so). Could this be caused by debris somewhere in the bonnet area of the PVB?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    The leak from the vacuum breaker prevents the downstream pressure from building up enough to "pop" the pop-ups. Repair the vacuum breaker.
  4. captwally
    captwally New Member
    Apr 30, 2005
    Apartment Complex Maintenance, Professional Chef
    Florida
    A repair kit is avaliable that includes the bonnet and seals
Similar Threads: Wilkins leaking
Irrigation / Sprinkler Forum Leaking Wilkins 720A PVB Jun 15, 2011
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Wilkins vacuum pressure breaker issue? Sep 15, 2009
Irrigation / Sprinkler Forum Wilkins Vacuum Pressure Breaker Jul 15, 2009
Irrigation / Sprinkler Forum which 'wilkins' check valve should I use? May 18, 2007
