Why won't garbage disposal reset?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Blumengarten, Mar 14, 2009.
  1. Blumengarten
    Blumengarten Member
    Nov 24, 2008
    new graduate
    Pennsylvania
    The garbage disposal got over-filled and stopped. I cleared everything out of it, pressed the reset button, and turned it on. I could hear the engine whirring, but not engaging. I checked to make sure there was nothing left inside, I couldn't feel anything, I unplugged it, pressed the reset button, turned it on, and same result. Do you know what's the matter?
    Thanks,
    Joy
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    It is jammed. Turn it off and use the tool that comes with the disposail and insert it in the socket in the bottem of the unit and give it a few good turns. Remove the tool, then try running it again. The tool looks like this.
    [​IMG] [​IMG] [​IMG]
  4. Blumengarten
    Blumengarten Member
    Nov 24, 2008
    new graduate
    Pennsylvania
    Okay, thanks! I wondered what that was for.
  5. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Let us know if it worked.
  6. hj
    disposer
    There is no "engaging". If the motor runs so does the grinding plate. You are hearing the motor "trying" to run and if you leave it on too long the reset button will pop out again. Unjam the disposer and remove whatever is causing the jam before trying to run it again.
  7. Blumengarten
    Blumengarten Member
    Nov 24, 2008
    new graduate
    Pennsylvania
    Yes thank you! :) I didn't know what that little wrench was for. Thanks for your help!
  8. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Awesome, always glad to be of a help. Most people have no idea what that wrench is for. It also serves another purpose for installing and removing the disposal from its flange. I have had home owners call me to tell me I forgot a tool behind.
    [​IMG]
  9. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Whenever I install a disposer it includes a lesson of how to unjam a disposer.
    If I'm sent a call to unjam a disposer the same lesson is also included.
  10. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    I was taught to tighten the last space left with a pair of channel lock pliers. Squeeze the two together and drive away.
  11. Blumengarten
    Blumengarten Member
    Nov 24, 2008
    new graduate
    Pennsylvania
    That's a good policy! Your customers surely appreciate it! (I'd feel silly calling a plumber to unjam a disposer, I'm so glad I found this website!)
  12. kingsotall
    Aug 17, 2008
    I've had some that were a real bear to unjam. One had a brad nail in it. That sucker took some ingenuity to finally get out.
  13. Redwood
    Dec 15, 2007
    Service Plumber
    I've seen that a couple of times...
  14. Redwood
    Dec 15, 2007
    Service Plumber
    I consider it to be an important part of taking care of the customer.
    Maybe a good reason to use my services again when really needed.
  15. Cookie
    Cookie .
    Oct 7, 2005
    I've unjammed mine with the end of a broom.
  16. kingsotall
    Aug 17, 2008
    I need to work on this more often. Sometimes when a job goes fast there can be time to educate the customer. Just gets hard when you're late for the next customer.
  17. kingsotall
    Aug 17, 2008
    There's some of that ingenuity I was talking about. :cool:
  18. Redwood
    Dec 15, 2007
    Service Plumber
    An educated consumer is my best customer.
    Besides I consider the rates we charge for unjamming a disposer to be a tad bit on the steep side.:D
  19. Cookie
    Cookie .
    Oct 7, 2005
    A plumber taught me that, lol.:p
    Granted my blades are so sharp that they can't cut up lettuce, but, it is not jammed either. :)
    Let Cookie educate you.
    Cookie's School of DIY Plumbing.
    I got some other tricks. Actually, only use the broom trick if it is frozen.
  20. Redwood
    Dec 15, 2007
    Service Plumber
    Some of those off brands you can't use a wrench on...
  21. Cookie
    Cookie .
    Oct 7, 2005
    A broom is universal can be used on all makes and models. :)
Similar Threads: won't garbage
Plumbing Forum, Professional & DIY Advice Humming Garbage Disposal Won't Start But Runs With Hand Start Jan 4, 2015
Plumbing Forum, Professional & DIY Advice Shutoff Valve Won't Open Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sinks won't drain after renovation Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Toilet seat won't stay tight Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Water won't shut off Sep 10, 2016
