Why should dishwasher drain go to disposal inlet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dayster, Jun 20, 2007.
  1. dayster
    dayster New Member
    Jun 20, 2007
    Vancouver, BC
    [​IMG]
    In a double sink situation where 1 sink has a garbage disposal, I have seen it stated that the dishwasher drain "must" be hooked into the inlet on the disposal provided for this purpose. Rather than to the other sink tailpiece.
    Any reason why?
  2. jimbo
    jimbo Plumber
    I don't know that it is mandatory.....it's just convenient.
  4. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    The benefit is worthwhile as the periodic use of the dishwasher helps to keep that grinding chamber free moving, along with the benefit of the sound dampening rubber diaphragm. Installing into a tapped tailpiece will produce a louder sound when the dishwasher is operating.
    Those who know safety, use Air Gaps to that dishwasher.
  5. hj
    Dw
    One benefit is that any food particles washed out of the dishwasher will be ground up by the disposer instead of going full sized down the drain. But otherwise you can run it to either spot.
  6. dayster
    dayster New Member
    Jun 20, 2007
    Vancouver, BC
    Thanks guys!
  7. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Food particals and grease...better to have them discharge into a disposal than a plain tailpiece when available....sorry "rugged" fella, I forgot...be sure to put a cleanout thingy there too.
Similar Threads: should dishwasher
Plumbing Forum, Professional & DIY Advice Should I give the dishwasher its own trap? Aug 8, 2013
Plumbing Forum, Professional & DIY Advice How should this humidifier overflow be plumbed? (pics) Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Surface Rust / Cracking at Kitchen Sink hole - Should I repair it or ignore it? Oct 22, 2016
