Why don't they make 80 gallon gas water heaters?
Discussion in 'Water Heater Forum, Tanks' started by BernieGallagher, Aug 19, 2011.
  1. BernieGallagher
    BernieGallagher New Member
    Aug 19, 2011
    Landlord
    Synecdoche, NY
    I'm renovating an old multi-family home and intend to live in one of the units. I like to take long hot showers, so I plan to replace the w/h for my unit with an 80 gallon w/h. This house has gas hookups for the water heaters rather than electric. Fine by me! But in shopping around, I've discovered that the largest gas water heaters they make are 50 gallons. If I want an 80 gallon w/h, I have to get electric. Why don't they make gas water heaters bigger than 50 gallons?
  2. Terry
    Aug 17, 2004
  4. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    There are 80's available as Terry notes. However, unless you are using an old high gpm showerhead (or an array of the standard 2.5 gpm showerheads) you should be able to take a really long shower with a 50 gallon tank. I use some ultra low flow showerheads now (around 1.5/1.6 gpm) and we can run three showers simultaneously, and dishwasher or washing machine too without ever running out of hot water. I'm not suggesting you go to an ultra low flow showerhead, but you might want to try to find a regular 2.5 gpm (they all say they are low flow anymore) that you like. Frankly, I didn't get great showers from the old 5 - 9 gpm showerheads I've used in other homes we were in. We had one house where my wife routinely ran the hot water out with a poorly performing high flow showerhead before I got in the shower...so I hated the damned thing. My wife prefers some inexpensive 2.5's, but she's at peace with the 1.6 gpm I found for her.
    Now if you want to fill a whirlpool tub...well the 50 gal comes up a big short for us using 125 F water setting. I have to halt the fill about 2/3 of the way, let the tank recover for about 15 minutes, then finish. So for that I would like to have an 80 gallon tank.
  5. Terry
    Aug 17, 2004
    Or you can add a tempering valve and run the water heater at the high setting, dialing it down for a mixed output at a lower temperature.
  6. jimbo
    jimbo Plumber
    San Diego, CA
    With Obama in office, and algore still on the loose, that will soon be illegal!
    BTW, a 50 gallon gas will give you approximately the same first hour delivery as an 80 gallon electric,due to the much higher recovery rate.
  7. hj
    That question ranks up with "what is the meaning of life". They DO make 65 and 75 gallon domestic gas heaters, but their cost is about two to three times the price of a 50 gallon one, and the 65 costs more than the 75.
Similar Threads: don't gallon
Water Heater Forum, Tanks Don't Know Leak Source Mar 29, 2015
Water Heater Forum, Tanks Why don't gas water heaters have dampers to reduce standby losses? Jun 20, 2012
Water Heater Forum, Tanks Rheem 80 Gallon Hybrid - not going over 125 Mar 3, 2017
Water Heater Forum, Tanks Best 40 gallon gas water heater in Pacific northwest? Nov 23, 2016
Water Heater Forum, Tanks Loud burner? 75 Gallon US Craftmaster water heater (propane) see pic? Oct 25, 2016
