Why are these voltage readings normal?
Discussion in 'Electrical Forum discussion & Blog' started by scubar, Jun 19, 2009.
  1. scubar
    scubar New Member
    Jun 19, 2009
    I've removed a Lutron dimmer switch with the goal of installing a regular light switch. There are two romex sets of wires coming into the box. One set reads a normal 118VAC between black and white. But the other set reads nothing between the black and white wires but on that set, there is 118 VAC between the black wire and ground AND between the white wire and ground.
    Why do the readings on the second romex set make sense? Where would they be getting power from? The power goes away from all of the wires when the breaker is opened.
    Appreciate your explaination on these readings.
    Ron
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    The black and white are connected together (maybe by an incand. lamp filament)?
  4. drick
    drick In the Trades
    May 16, 2008
    Who said they did? Cheap digital DMMs are notorious for picking up stray voltages.
    Its induced voltage it picks up off other wires it runs next to in the ceiling/ wall/etc.
    Because you shut off the wire inducing the voltage.
    Ok now before you go blowing your fingers off check if I'm right. Connect a test light between the ground and the white wire in the second set. Did it light up? If yes then I'm wrong and something else is going on. Otherwise its safe to say that the first pair is power and the second pair is from the fixture. Connect the whites from each pair together and wire the switch between the blacks.
    rick
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
  6. scubar
    scubar New Member
    Jun 19, 2009
    Thanks for your responses. The switch works fine and the voltage was likely feed through another lamp.
    Ron
Similar Threads: voltage readings
Electrical Forum discussion & Blog Voltage readings Sep 4, 2007
Electrical Forum discussion & Blog Activating Pump via low voltage switch input Feb 11, 2017
Electrical Forum discussion & Blog Exceptable voltage levels for 120V? Aug 15, 2016
Electrical Forum discussion & Blog Does each leg of a 220 line have to have the exact same voltage? Jul 25, 2016
Electrical Forum discussion & Blog Intermittent low voltage on one leg Jul 18, 2016
