Whole house filter with jet pump and pressure tank
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mbinetti, Nov 28, 2011.
  1. mbinetti
    mbinetti New Member
    Nov 28, 2011
    BDA, NJ
    Hello everyone,
    I need a little advice. I apologize if this subject has already been addressed. I have 1.0HP Myers jet pump and I believe a 14 gallon pressure tank. My pressure switch was originally 40/60. Anyway, about 7 months ago I installed a whole house filter (AP907) after the pressure tank. I think it is starting to clog up because I can no longer have two draws on the system at the same time. If I am taking a shower, no one can run the kitchen sink. I initially tried increasing pressure from the switch, its set at about 45/63 now but still the same problem. I can replace the filter but its supposed to last a year. I am thinking of raising the pressure switch again to 50/65 but wonder what other options I may have.
    Does anybody have any advice to increase my pressure? thanks in advance.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Change the filter and/or install two in parallel.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I hate whole house filters but if you must, you must also maintain them. Change the element and presto......life is better, for awhile anyway
  5. mbinetti
    mbinetti New Member
    Nov 28, 2011
    BDA, NJ
    I know what you mean about the WHF, but it is necessary. I rather not change the filter so soon. So would a CSV be of any use? Any other constant pressure solution out there? Should I be worried about the 65-70 pressure setting? I should also note it is a 3/4 HP not a 1 HP jet pump. Any more advice would be helpful.
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    A CSV would do nothing for loss of volume which is what the WHF is causing. Either get a bigger filter that can provide more GPM or twin two in parallel.
  7. Tom Sawyer
    Nov 29, 2010
    Maine
    No, change the damn filter, it's plugged up. Would you leave a plugged oil or fuel filter in your car?
Similar Threads: Whole house
Pumps and Tanks Well Forum & Blog. Water is life. Well to pressure tank to whole house filter to Jun 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. whole house filter, AFTER WellTroll tank? Jan 8, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Whole house filtration for well water question May 4, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Lakos Sub-K vs. SandMaster PLUS for sand/sediment mitigation (whole house+irrigation) Dec 15, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Whole house shutoff/leak detection system Nov 22, 2013
