Who turned the lights out? (I did)
Discussion in 'Electrical Forum discussion & Blog' started by ian1511, Mar 30, 2012.
  1. ian1511
    ian1511 New Member
    Mar 30, 2012
    Wisconsin
    Was placing a screw to secure a wall outlet receptacle in my garage. Had just painted that wall. Had to jiggle it a little and sparks appeared, I let go and all the lights in the room and the adjacent room went out. Garage door opener also won't work. The strange thing is that the circuit breaker does not show the fuse tripped on that circuit. Just to check, I turned the circuit off and then back on and still no lights. Where might the problem be? What do I need to change or fix?
    Thanks,
    Ian
  2. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Quite possibly a wire splice came apart in the box you were messing with. Make sure all the wires in the box are dead
    before investigating.
  4. hj
    If the lights did not go out until you released it, then it was not the circuit breaker. More likely a loose connection.
  5. jadnashua
    Often, especially if it is to code, things in the garage are protected by a GFCI...find it and reset it, and things will probably work again...could be something else, but that one is fairly common.
  6. drick
    drick In the Trades
    May 16, 2008
    Look for a GFCI first, but breakers are known to fail. Where you have multiple rooms out I'm leaning toward the breaker. Don't just assume it is still working and passing current just because it didn't trip and you can still reset it. Usually it takes feeding the other half of the split phase back at the breaker to kill it, but they are mechanical and do sometimes just die.
    -rick
Similar Threads: turned lights
Electrical Forum discussion & Blog Switch turned off, getting weird multimeter reading Mar 14, 2015
Electrical Forum discussion & Blog GFCI Trips when Light Switch is Turned Off Jul 24, 2008
Electrical Forum discussion & Blog Fuse blown after plugging in heater now light dims when another is turned on. Mar 28, 2008
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Lights won't turn off, sometimes if switch is halfway Aug 24, 2016
