White, wax paper like residue in Moen cartridge
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by revie54, Mar 14, 2013.
  1. revie54
    revie54 New Member
    Mar 14, 2013
    California
    I have a strange thing happening. My tub faucet started leaking so I went to replace the cartridge as I have done a few times before. When I removed the Moen cartridge it had a bunch of pieces of little wax like paper stuck in different parts of the cartridge. I put in a new cartridge and it started leaking again a couple of days later. When I pulled out the new cartridge it also had this wax paper stuff clogging it up. Any ideas what this stuff is and how to get rid of it? Thanks.
  2. Terry
    Aug 17, 2004
    Small white plastic particles would perhaps be a water heater dip tube.
    Is it on the hot or the cold side?
  4. revie54
    revie54 New Member
    Mar 14, 2013
    California
    Thanks for the reply. It is a single handle faucet. It does not look like the little residue that I see when I drain the hot water heater (it is real old) if that's what you are talking about.
  5. revie54
    revie54 New Member
    Mar 14, 2013
    California
    It is more like little tiny strips of wax paper
  6. jadnashua
    There was a batch of water heater dip tubes that failed - they literally broke up into small white flakes. An old WH might have had one in it...that event was a long time ago. This did two things: clogged up valves, shower heads, and aerators; and, caused you to run out of hot water faster since instead of adding the cold water to the bottom of the tank, it mixed with the hot at the top.
Similar Threads: White paper
Plumbing Forum, Professional & DIY Advice Replace HW heater anode rod ... Bradford White combination outlet/rod Jan 19, 2016
Plumbing Forum, Professional & DIY Advice White stains and rust on copper pipes Feb 3, 2015
Plumbing Forum, Professional & DIY Advice Bradford White Hot Water Heater Pilot Flame Jan 15, 2015
Plumbing Forum, Professional & DIY Advice ABS joint turned from yellow to white May 21, 2014
Plumbing Forum, Professional & DIY Advice What's this white plastic debris in aerators? Bad dip tube. Dec 29, 2013
