White specks in water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Garydaplummer, Jun 16, 2010.
  1. Garydaplummer
    Garydaplummer Union plumber/pipefitter-self employed
    Jan 5, 2008
    Mechanicsburg, PA
    I have a customer who was experiencing whilte specks in their kitchen faucet, a pull-out sprayer type Delta. The faucet aerator was getting blocked by them. I took the spray head off the hose and ran water in a glass, it only came from the hot water. These specks were soft to the touch. I thought dip tube and my supply house rep agreed (Bradford White electric) so we ordered another one for the water heater. When I went to install it the original dip tube looked in tact, but I went ahead and replced it anyway, it was quite brittle. Now, about 5 months later, they call back that this has happened again. It seems to be only at the kitchen sink and after talking to the local rep and the Bradford White rep originally we all came up with the idea that it was because that was the closest hot water outlet off the water heater that it was showing up there. Now of course that diagnosis is suspect. Any similar experiences out there? I checked the under sink plumbing, copper with chromed supply tubes. The specks are white in color, very small, and when you rub them between the fingers they break apart.
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    test the water
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Test the particles with vinegar,
    If they dissolve they are minerals...
    If they don't they are dip tube...
    Part of replacing the dip tube is flushing it out...
    Not an easy task...
Similar Threads: White specks
Plumbing Forum, Professional & DIY Advice White Spot on Pipe Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Replace HW heater anode rod ... Bradford White combination outlet/rod Jan 19, 2016
Plumbing Forum, Professional & DIY Advice White stains and rust on copper pipes Feb 3, 2015
Plumbing Forum, Professional & DIY Advice Bradford White Hot Water Heater Pilot Flame Jan 15, 2015
Plumbing Forum, Professional & DIY Advice ABS joint turned from yellow to white May 21, 2014
