White Rodgers 535 Limit Switch Replacement
Discussion in 'HVAC Heating & Cooling' started by Wrex, Apr 14, 2008.
  1. Wrex
    Wrex New Member
    Mar 19, 2008
    New Jersey
    My Mueller furnace's limit switch has just bit the dust and its time for replacement due to erratic operation.
    The old switch is a White Rodgers Model 535 that isn't manufactured anymore. It is a combination switch that has both fan and limit functions.
    I removed it to check it out and the elements that extend over the bonnet measure 16 inches from the unit to the tip.
    I have found a unit that is identical to the old unit.
    I have two White Rodgers models for replacement in mind either the:
    The 5A75-5 only has a 9 inch element which isn't as long as the old switches elements were.
    The 5A75-12 has the same 9 inch element but has a 60 inch capillary so it gives me the extra reach I need.
    This is the one I am really considering but I have one concern. Isn't the 60 inches a bit extreme? Would the extra length effect the reaction time of the switch?
    The extra capillary would be coiled if I use the 5A75-12.
    Here is a link for a visual between models:
    The 5A75-12 is on the left while the 5A75-5 is on the right.
    Thanks for the help in advance.
Similar Threads: White Rodgers
HVAC Heating & Cooling Comparing 3 Thermostats White-Rodgers, Lux and Jackson Jun 8, 2013
HVAC Heating & Cooling Replace White-Rodgers IF92 Tstat with new Honeywell VisionPro Jun 23, 2010
HVAC Heating & Cooling White Rodgers 13a02-102 May 30, 2008
HVAC Heating & Cooling White-Rogers Thermostat to Hunter 44660 Dec 7, 2008
HVAC Heating & Cooling Bradford White Defender / gas water heater tripping Sep 8, 2008
