white residue from faucet install?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hogu, Oct 24, 2012.
  1. hogu
    hogu New Member
    Oct 24, 2012
    new york, ny
    I had a new faucet installed, and the guy used a clear sealant around the base plate (plumber's putty?) Faucet works great, however when it gets wet, it gives off a white residue. Do you guys know what that is? Is it bad that this is happening? Is that stuff toxic? Thanks!
  2. hj
    If it is clear, it is NOT plumber's putty. He may have used a clear "tub and tile caulk" which is white when it is applied but turns clear when it dries. If so, water might "reactivate" it and turn it back to white until it dries again. It is NOT toxic.
Similar Threads: white residue
Plumbing Forum, Professional & DIY Advice White, wax paper like residue in Moen cartridge Mar 14, 2013
Plumbing Forum, Professional & DIY Advice Replace HW heater anode rod ... Bradford White combination outlet/rod Jan 19, 2016
Plumbing Forum, Professional & DIY Advice White stains and rust on copper pipes Feb 3, 2015
Plumbing Forum, Professional & DIY Advice Bradford White Hot Water Heater Pilot Flame Jan 15, 2015
Plumbing Forum, Professional & DIY Advice ABS joint turned from yellow to white May 21, 2014
