White milky water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Nedbrod, Dec 22, 2008.
  1. Nedbrod
    Nedbrod New Member
    Dec 10, 2008
    trades supervisor
    new jersey
    Hey Guys,
    I can't for the life of me figure this one out. I supervise trades personnel at a small commercial building. Recently, we had a 12" water main break about 200 yards away from the building. We replaced a 12" gate valve that was broken, flushed the line at a fire hydrant 50 yards prior to the building and then set about purging air from the rest of the facility. This includes three showers, twenty-two sinks, nine urinals and nine toilets. Everything seems to be fine except that the hot water comes out of the faucets looking like 1% milk!! If you let it sit in a glass or bowl for a few minutes it clears right up as there is no residue in the glass so it appears to be only really fine air bubbles. We have not made any changes to the hot water system which is a two year old electric unit with a circulating pump. I'm not receiving complaints about the hot water but it looks terrible! Any thoughts on what I might look for as the problem? Thanks.
  2. Ian Gills
    Jul 24, 2007
    USA
    Surely this is just air that will disappear, as you point out.
    Perfectly normal following a leak of that magnitude.
  4. WV Hillbilly
    WV Hillbilly New Member
    Aug 1, 2008
    WV
    Milky color
    Water contains dissolved oxygen and other gases. When it's heated it has less ability to hold these gases and when the pressure is lowered as the liquid comes out of the tap these gasses can form tiny bubbles giving the liquid a milky appearance. Letting it stand for a few minutes will allow these bubbles to rise out of the liquid and it resumes its clear appearance.
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    It's air and it is probably a suction leak at the valve causing it.
Similar Threads: White milky
Plumbing Forum, Professional & DIY Advice White Spot on Pipe Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Replace HW heater anode rod ... Bradford White combination outlet/rod Jan 19, 2016
Plumbing Forum, Professional & DIY Advice White stains and rust on copper pipes Feb 3, 2015
Plumbing Forum, Professional & DIY Advice Bradford White Hot Water Heater Pilot Flame Jan 15, 2015
Plumbing Forum, Professional & DIY Advice ABS joint turned from yellow to white May 21, 2014
