white build up around taps
Discussion in 'Water Softener Forum, Questions and Answers' started by K Paterson, Nov 7, 2013.
  1. K Paterson
    K Paterson New Member
    Nov 10, 2009
    Hamilton, Ontario
    I had a very very old water softener using alot of salt. It finally broke. I replaced it with a Fleck 5600SXT. After having it installed professionally and using it for a year I continue to get a white (assume calcium) build up on my taps. Here are the settings for the Fleck. I currently use Culligan Salt. All functions seem to work, I am hoping it is just a settings issue. Please help.
    Single Tank
    C: 24.0 x1000
    H: 79 (my hardness is closer to 70)
    RS: SF
    SF: 0
    RC:0
    DO: 3 (prefer just to regen every 3 days)
    RT: 2:00am
    BD: 60
    BF: 11 ( was 8 2mths ago, changed hoping to improve on problem)
    BW: 13
    RR: 13
    BLFC size is 0.5GPM
  2. K Paterson
    Nov 10, 2009
    Hamilton, Ontario
    Sorry late update: 2 months ago I had my water tested and was told I had a -1 ion, so I bumped my BF to 11, previousy 8, but still same problem. Thanks
  4. lifespeed
    lifespeed Member
    Apr 27, 2007
    California
    Post your water test results.
  5. Noyzee1
    Noyzee1 Member
    Sep 7, 2013
    SoAz
    Is it possible that the white buildup is now sodium instead of calcium chloride or magnesium chloride? You can't remove the solids via ion exchange, just convert them to sodium, AFAIK.
    Cheers,
    JIM
  6. ditttohead
    Jan 9, 2012
    Ontario California
    Sodium will leave spots, but these are almost instantly dissolve with the next use of water. There are many other factors that could be causing this. Without a detailed water report, we would only be guessing wildly.
    Technical silliness below,
    Ion Exchange is used to remove TDS. DI resin replaces the negatively and positively charged ions in the water with H+ & OH-, or water. DI resin would not normally be used in a residential application of course. I have a large DI system at my house, but this is for the carwash and is pretreated with an RO system.
Similar Threads: white build
Water Softener Forum, Questions and Answers Water Softner White Residue Sep 11, 2015
Water Softener Forum, Questions and Answers Kenmore Water Softener white 1" Disk Nov 27, 2014
Water Softener Forum, Questions and Answers New Water softener, but still have white residue in water Dec 28, 2009
Water Softener Forum, Questions and Answers Rebuilding Fleck 2500 valve Jan 22, 2017
Water Softener Forum, Questions and Answers Water Filer Build / Parts list Aug 15, 2016
