Whirlpool spa and Plumbing codes
Discussion in 'Shower & Bathtub Forum & Blog' started by scatkins, Jun 30, 2006.
  1. scatkins
    scatkins New Member
    Jun 30, 2006
    Question about plumbing codes (I'm in southern california)
    I'm replacing a bathtub with a fiberglass Whirlpool spa (non-heated). I realize that it is is a good idea to provide access to the motor as well as to wet wall access covers (which of course is at opposite ends of the tub).
    But my real question is ware the plumbing code requirements. I read conflicting things. Some say that access covers to these items is required. Others say that the access to the wet wall hasn't been required for years?
  2. hj
    access
    I haven't seen a new house with an access opening, other than for the pump, for decades.
  4. scatkins
    scatkins New Member
    Jun 30, 2006
    Based on my reading of the current plumbing codes: the code is that you need access if you are using a slip joint (i.e to tie the tub tailpipe to the trap) in tub installations.
    So, I guess nowdays the trend is to use ABS/PVS and use perm glue joints. So if you do that no access is needed. (Thus no-one puts in access anymore)
  5. The Marble Guy
    The Marble Guy Cultured Marble installer /remodeler
    Aug 27, 2006
    Texas Panhandle
    Scat,
    Depending on the model of tub you purchase, some come equipped with a removable skirt(panel). You can also get a cultured marble one and silicone it to the front of the tub if it is open. It is removable with a razor knife and a putty knife. I replaced a motor on a tub Friday and had the skirt off and on in 15 minutes.
    Another solution is to place a return air vent in the stud space next to the motor if possible. The motor can usually fit thru the vent. It won`t hurt to have some ventilation under the tub either.
    good luck
    TMG
Similar Threads: Whirlpool Plumbing
Shower & Bathtub Forum & Blog Plumbing for a new whirlpool corner tub Nov 18, 2006
Shower & Bathtub Forum & Blog Mortar bed under fiberglass whirlpool tub - How thick?? Mar 27, 2015
Shower & Bathtub Forum & Blog Delta Roman Tub faucet for Whirlpool, tub spout Sep 30, 2013
Shower & Bathtub Forum & Blog Recommend a whirlpool tub for tub/shower combo? May 15, 2013
Shower & Bathtub Forum & Blog need help with Whirlpool tub Mar 23, 2013
