Whirlpool Heat Traps, leave in place or remove?
Discussion in 'Water Heater Forum, Tanks' started by spieg, Jan 24, 2013.
  1. spieg
    spieg New Member
    Jan 24, 2013
    North Carolina
    I have purchased a Whirlpool 50 gal electric water heater to replace a unit which has been in service since 1989. The inlet and outlet nipples are equipped with heat traps which are recessed about 5" into blue plastic liners or tubes inside a metal nipple with threads. I have read blogs that mention these heat traps as culprits in reducing water pressure to the faucet. I don't imagine the old heater had any heat traps so wondering whether I need to be concerned with the heat traps in this new heater changing water pressure? Is it possible to just remove the rubber flaps or does the entire nipple (dielectric) have to be unscrewed? What is the best method to extract the flap valves? If the consensus is that they should be left in place I will install the heater as is. I will be using gator bite connectors to connect 3/4" copper pipe from the old heater installation to the threaded nipples to avoid any soldering/heat. I should have mentioned that I am on well water. Thanks for any comments and or advice.
Similar Threads: Whirlpool Heat
Water Heater Forum, Tanks Whirlpool 10 year old Water Heater Mar 4, 2017
Water Heater Forum, Tanks Whirlpool water heater date Aug 22, 2015
Water Heater Forum, Tanks Getting a rash of bad Whirlpool heaters Feb 1, 2015
Water Heater Forum, Tanks Whirlpool Flame Lock Heater Often Fails to Maintain Hot Water ("False" Status Light) Jul 6, 2012
Water Heater Forum, Tanks Help! Whirlpool Water Heater Problem Oct 14, 2010
