Whirlpool bath problem
Discussion in 'Shower & Bathtub Forum & Blog' started by vito, May 16, 2010.
  1. vito
    vito New Member
    May 16, 2010
    Indiana
    I have a situation I need help with. A neighbor has an Eljer corner whirlpool bath. We installed and tested and it was ok. At some point, a leak emerged in the plumbing on the side of the tub buried in the wall. I cut out some drywall and using a mirror, identified a cracked PVC pipe at a "T" fitting coming off one of the jet housings. The crack is right up by the fitting in 1 inch PVC, so I can't splice a coupling in. 2 options I am looking at that I would like advice or information if someone has it.
    1. The jet housing appears to be silicon sealed to the back of the tub. There is a trim ring on the inside of the tub that also looks like it is siliconed in place. There are some notches on the inside of the trim ring that makes me think this might be removeable with a spanner type wrench. Any suggestions? It is about a 2 inch diameter trim ring.
    2. If I can get the housing loose, I plan to cut the lines in the wall and pull the housing out to work in a better environment. If I can, or even if I can't, I am thinking of trying to drill the broken 1 inch pipe out of the 1 inch "T" fitting. I have seen some drill bits on line that have a pilot the size of the ID of the pipe and a cutter the ID of the fitting. Has anyone ever used such a tool?
    The whirlpool is an Eljer premiere triangle model. Any advice is appreciated.
  2. jadnashua
    There are drill bits designed to drill the pipe out of a fitting...not sure they make one in that size, but if they do, and you can get access, that should work. It's possible that the pipe to the jet connection is putting stress on things because it isn't lined up and if so, this may break again. If so, it sounds like a manufacturing defect...the stuff shouldn't crack. When was it installed? Have you talked to the manufacturer? Can you post a picture?
  4. vito
    vito New Member
    May 16, 2010
    Indiana
    Thanks. A picture is a problem. I'm working with a very small access hole going down the wall cavity and then under the tub. The tub was purchased about 9 months ago, and installed this past January. The leak was detected in February, but just now getting around to repair. It was a homeowner install, so I don't know that there is much room for a warranty claim. I think the cutter tool in a right angled drill is the ticket, hopefully it will go ok.
  5. jadnashua
    At only 9-months, it's worth it to call the manufacturer for guideance.
Similar Threads: Whirlpool bath
Shower & Bathtub Forum & Blog Jacuzzi whirlpool bath Jan 31, 2011
Shower & Bathtub Forum & Blog Whirlpool bathtub framing questions... Oct 2, 2009
Shower & Bathtub Forum & Blog Air bath whirlpool tubs???? Jul 9, 2009
Shower & Bathtub Forum & Blog Which Brand "air bath / whirlpool " tub to buy?? Jun 18, 2009
Shower & Bathtub Forum & Blog Installing jacuzzi 6060 whirlpool bath Jun 1, 2008
