whining from water pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hunyduz, Feb 27, 2007.
  1. hunyduz
    hunyduz New Member
    Feb 27, 2007
    I had 120 lbs of pressure due to a faulty PRV. I replaced it, and the reduced pressure (73lbs) did not allow the two upstairs toilet valves to open. They were replaced and now work fine.
    The cold water line whines when any cold water faucet is used, so I cannot isolate the problem to a specific valve.
    As the lines stabilize might it stop? Any ideas?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Since the PRV and 2 fill valves were replaced try shutting off the fill valves 1 at a time and run the water and see if the noise goes away / changes. If not it may be a faulty PRV. You could try and change the pressure down 10# and see if it makes any difference.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    I once had whinning from a supply tube going to a toilet. Did you change them at the same time ?
  5. hunyduz
    hunyduz New Member
    Feb 27, 2007
    I did replace them at the same time.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Did you use stainless steel flex connectors or the solid plastic type?
  7. hunyduz
    hunyduz New Member
    Feb 27, 2007
    I used stainless steel.
    I shut off the toilet valves one at a time, then both and still had the noise.
    It appears to be initiated by the faucets in the upstairs bath, the furthest from the intake lines. Using other faucets does not do this until the upstairs faucets (now BOTH hot and cold) are used.
    I've avoided adjusting pressure, but I may have to.
  8. coz
    coz New Member
    Feb 27, 2007
    MA
    lbs
    73 lbs is borderline high. see if you can get it down to say 55 and see if your problem goes away. I have had to double PRV`s to knock down pressure that high, A cheap valve will not last long. notice they range from 45 to 125 bucks for the same pressure ratings
  9. hunyduz
    hunyduz New Member
    Feb 27, 2007
    I further reduced the pressure to 60, and the whining is now very infrequent.
    Hopefully, a further reduction will not be needed. It all depends on what my wife decides.
Similar Threads: whining water
Plumbing Forum, Professional & DIY Advice Water Pipes Howling/Whining Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Whining/noise returns after expansion tank install on cold water line - help!! Jun 9, 2012
Plumbing Forum, Professional & DIY Advice Whining coming from capped off pipe Jun 26, 2015
Plumbing Forum, Professional & DIY Advice toto CST604CEFG BOWL FILL S UP THEN TOILET MAKES WHINING SOUND AND THEN KEEPS FILLING Jun 2, 2013
Plumbing Forum, Professional & DIY Advice Pipes humming/whining Jun 10, 2011
