Which way do faucet knobs turn?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by eagleeye, Dec 23, 2007.
  1. eagleeye
    eagleeye New Member
    Dec 23, 2007
    Can someone please tell me what is the correct direction for the hot and cold faucet knobs to turn on/off. This is for my bathroom sink. It's a Delta faucet and the hot and cold knobs are round.
    I always thought hot was clockwise, and cold was counterclockwise.
    Seems like a simple question, but I've been searching google for half an hour and can't find out.
    Thanks
    Jeff
  2. Terry
    Aug 17, 2004
    It's both ways.
    With Delta, you can pull the cartridge and make it go either way.
    With levers, they normally open toward the middle.
    With knobs, they can open counter clockwise, but not always.
  4. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Lefty loosey
    Righty tighty
    But back in the day of separate hots and colds....
    hot turned clockwise to on
    cold turned counter-clockwise to on
    reverse both to turn off
    Micajah likes this.
  5. hj
    Huh?
    That would make lever handles open away from you. Mine always were just the opposite of that and only with lever handles. Round handles ALWAYS opened counter clockwise, unless they come from one of the specialty companies who send all valves out as if they had lever handles.
  6. Micajah
    Micajah New Member
    Sep 14, 2016
    Massachusetts
    Dunbar Plumbing has it right for setting up knobs and cross handles. If you are using levers it would be opposite, the handles would point at you when on/ open. Swapping the valves is how you would correct the rotation between knob/ cross and levers. Most of the instructions do not mention this.
  7. hj
    quote; Dunbar Plumbing has it right for setting up knobs and cross handles
    Huh? He has it right for the cold water using round handles, but for everything else it is incorrect. The only time they are different is if it is a lever handle on a bath tub wall mount faucet, THEN the handles rotate backwards so they rotate upwards to turn on so heavy handles, or loose stems, do NOT cause the valve to turn on by themselves. Some valves have an external device to change the rotation without removing the stems.
  8. plumber69
    plumber69 Member
    Jun 20, 2014
    Prince Rupert, British Columbia
    What happend is a handy man came and fix it and you got used to it. Both can turn clockwise. One can turn opposite from other.
  9. plumber69
    plumber69 Member
    Jun 20, 2014
    Often there is a hot and cold cartridge
  10. hj
    When I find handles turning the wrong way, I ask the customer if they want me to correct it. Otherwise, they will try to operate the faucet and think it is broken.
Similar Threads: faucet knobs
Plumbing Forum, Professional & DIY Advice Please help identify this faucet brand TY Tuesday at 3:53 PM
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
