Which wax ring do you prefer?
Discussion in 'Toilet Forum discussions' started by rsmith99, Feb 16, 2013.
  1. rsmith99
    rsmith99 Member
    Feb 28, 2008
    Oklahoma
    I have a toilet that has been installed for about 2 years. Today I noticed a little seepage on one side by a grout line. The toilet is installed over tile on a concrete slab. The toilet is mounted solid and does not move. It has never been stopped up and never plunged. I don't understand why they just start leaking.
    Anyway, can anyone recommend a good wax ring? I have just always used the rings from the big box stores.
    Ron
  2. Terry
    Aug 17, 2004
    Unless the flange is above the floor, it's going to take two wax rings (or perhaps a thick one)
    Many tile floors are layered in such a way that the flange is too low for a single wax ring.
  4. jadnashua
    TO make a decent seal, you must be able to feel the toilet compressing the wax ring when you set it down.
  5. Hackneyplumbing
    Hackneyplumbing Homeowner
    Jul 30, 2012
    Alabama
    For floor mounted toilets I use a waxseal without the plastic handyman horn. IMO the horn only is there to restric flow and to allow splashing. The bottom of the flange should be sitting on the top of the finished floor. I only use one waxseal and with a correct flange height thats all that is needed. if the flange height is not corrrect then I make it correct.
    I do it right or not at all.
  6. Terry
    Aug 17, 2004
    Then you would be pretty busy in the State of Washington.
    At least 95% of new construction has the flooring cut around the flange making it recessed.
    The only really good way of raising the flange, would be to cut it out completely and install a new flange from scratch. Stacking waffers on top is a joke. Those leak worse then using wax.
    Though my customers get by fine and without leaks using two wax rings. Maybe they are just better at settiing bowls than the plumbers.
    Just saying...........
  7. Hackneyplumbing
    Jul 30, 2012
    Alabama
    I stay busy here correcting mistakes. With two wax rings when the sewer clogs your almost assured a leak. I cut them out and install a new one almost on every new toilet install. They are usually bowed from the pressure of the bolts pulling up on the flange or broke anyway. if your going to replace it might as well install it at the right height.
  8. Terry
    Aug 17, 2004
    With a new install, I like using the Sioux Chief rings that stack, underneath the flange. We didn't have those when I broke into plumbing.
  9. Hackneyplumbing
    Jul 30, 2012
    Alabama
    I made those by cutting the bottom off a regular pvc flange. AHHH the days. I'd like to break out of plumbing. LOL
    I like to replace the flange when the guy paying will let me is what I should have said. Thats the truth.
Similar Threads: ring prefer
Toilet Forum discussions Toilet Ring Leaking in Rental House Jan 3, 2017
Toilet Forum discussions Pouring muratic acid in the flush valve Nov 28, 2016
Toilet Forum discussions Floor mount rear outlet Barrington vs Yorkville Sep 16, 2016
Toilet Forum discussions Wax rings, Just got to ask... Aug 29, 2016
Toilet Forum discussions how often need change wax ring? affect flushing? rubber rings? Aug 12, 2016
