Which tub drain is best?
Discussion in 'Shower & Bathtub Forum & Blog' started by Barney1, Apr 24, 2007.
  1. Barney1
    Barney1 New Member
    Apr 10, 2007
    I’m replacing my bathtub and have to get an new drain as well. Is there one type better than the other? The three that I’m looking at are the conventional screen and lever type at the over flow or the push-in and lock type or the lift and turn type. Is one better than the other? The ones with the screen always seem to clog up with hair. Im wondering if the other two types have this problem. Thanks!
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    The ones I have installed here in my own home have the lever in the overflow and nothing but a screen at the actual drain opening ... and I believe that is the easiest and best for the catching and removal of hair.
  4. Barney1
    Barney1 New Member
    Apr 10, 2007
    Which of the three do you think would flow water the best?
  5. leejosepho
    Nov 23, 2006
    There is probably not much significant difference, but the lever-type has no integral obstruction anywhere.
  6. Cal
    Cal New Member
    May 10, 2005
    Northern Virginia
    The lift & turn is the best ! much easier to clean and works the best
    cal
Similar Threads: drain best
Shower & Bathtub Forum & Blog Your Beach House Shower: Best way of preventing sand build up in drain Dec 19, 2014
Shower & Bathtub Forum & Blog Best Drain Choice for a Solid Stone Shower Base (Made in Indonesia) Jul 8, 2014
Shower & Bathtub Forum & Blog advice on best way to get drain pipe to fit in new shower pan Jun 6, 2013
Shower & Bathtub Forum & Blog share your opinion on the best shower drain Mar 28, 2012
Shower & Bathtub Forum & Blog Need advice on best way to redo drain for walk in shower Dec 8, 2011
