Which stop valve do I use?
PM5K
San Antonio, TX
This question is in regards to stop valves for a bathroom sink.
I'm used to seeing either one of the following:
Copper supply, use compression fitting
Galvanized Steel, use threaded fitting
The current configuration is a copper supply with a threaded brass (can't be copper right?) end soldered on.
So what exactly do I do with this, buy a threaded brass stop valve?
Thanks in advance!
TMB9862
Use a 3/8" or 1/2" IPS by 3/8 compression valve. Brass and copper pipe threads are the same size as iron pipe threads.
PM5K
San Antonio, TX
I didn't think I could use a compression valve.
Here is what they look like for the record, although this isn't the one in question, it's the same:
Cass
It appears that you have a 1/2" copper male adapter...you will use a 1/2" IPS X 3/8" compression angel stop and I would suggest a 1/4 turn stop. Use Teflon tape on the threads.
Redwood
3/8" compression is probably the most commonly used size outlet for faucets, dishwashers, and toilets. 1/4" compression would be used for icemakers, point of use water filters, and hot water dispensers.
What do you have in mind?
NHmaster
S. Maine
sorry I'm busy right now sorting out a box of left and right 16D galvanized spikes.
PM5K
San Antonio, TX
Can you use a stop valve with a compression outlet by just screwing braided stainless supply line into it OR say using a copper or chrome plate supply line that's put on via a compression fitting, or is a compression stop valve only meant to be use one way?
Redwood
Use this type of connector it will thread right onto the valve. The one shown below is for toilets.
Note: Do Not Buy the the Watts Floodsafe Connectors that big orange box pushes.
Ian Gills
Senior Robin Hood Guy
USA
If any of you would like me to go to the storeroom and ask the bloke there for a left-handed anything, then please let me know.
PM5K
San Antonio, TX
Thanks, sorry for being such a noob, I've actually done this a few times before, but I saw what I was expecting to see, this time I didn't.
What's this left hand joke?
NHmaster
S. Maine
It's something we like to do to apprentices. Send them to the truck for a left hand pipe wrench, then wait to see how long they are gone. It carries over to all the trades.
rpaquet
That fitting in the previous picture shows a similar type on a new shower valve I put in. I just got around to checking today and I have some leaks. I used teflon tape. Will the leaks stop eventually?
Redwood
You used a connector like the one I pictured above to install a shower valve?
The one I pictured is for a toilet! It is not supposed to be used inside a wall.
The leak will not stop thats pretty much guaranteed...
Can you post a picture of it?
